Please bear with me. It's easier asking you guys opinion than to Google.
Especially choosing the right resistor when working with Arduino boards and transistors for relays.
Question in the title: How to choose the right transistor for a circuit and its associated resistor?
    \$\begingroup\$ What do you want to do with it, what particular circuit do you have in mind? \$\endgroup\$
    – jippie
    Feb 8, 2014 at 18:28
    \$\begingroup\$ Google also needs help when entering keywords or phrases. I see nothing in this question that would help anyone (or google) understand what you are trying to discover. \$\endgroup\$
    Feb 8, 2014 at 18:32
  • \$\begingroup\$ @andy ak - yes, google is awesome. But it teaches you to google something to google. I've been from forum to forum learning one by one, and its a good thing learning basics. But sometimes it's still better getting to the point then realizing the fundamentals afterwards. If my question troubles you, I'm sorry. And it will helps me so I hope there's something. \$\endgroup\$
    – yhunz_19
    Feb 8, 2014 at 18:43
    \$\begingroup\$ In my opinion asking us a sensible question after probing google sensible enquiries is a good way to go. I see no evidence that you have done this. I don't see a question that is possible to answer also. \$\endgroup\$
    Feb 8, 2014 at 18:50
    \$\begingroup\$ For what it's worth, I think most of the commenters who didn't understand the question, only read the text, not the title of the question. The title actually formulated a perfectly answerable question, if you make some common-sense assumptions. \$\endgroup\$
    – Jon Watte
    Apr 3, 2014 at 19:10
I'm assuming you mean a BJT (NPN or PNP) and not a FET (N-channel or P-channel.) I'm also assuming that you mean the base current limiting transistor.
You have to choose a transistor that has sufficient voltage and current rating for your load. For example, for a 12V relay coil, that may spike to 24V during inductive transients, use a 30V rated transistor. For a coil with a current rating of for example 80 mA, choose a transistor that is rated for at least that (although almost any transistor in a discrete package will be rated for at least that much.)
Finally, for the base current limiting resistor, look at the hFE of the transistor (let's say it's 10) and divide the load current (80 mA) by that (giving 8 mA.) Then look at the voltage you have driving the transistor, and the base-emitter voltage drop. The voltage that's left (say, 3.5V) divided by the base resistor should equal at least that current. Use Ohm's law. To drop 3.5V when delivering 8 mA, you need (3.5/0.008) 437.5 Ohms; better choose something slightly less.
In general, you want to memorize Ohm's law, and use it to analyze any kind of load/voltage/current question you have, as it's one of the most basic properties of electronics. You also want to actually read about and understand the components you're using, such as resistors (why does the wattage rating matter?) and transistors (what is hFE, what is voltage drop, etc.)
  • \$\begingroup\$ so nice! Exactly the kind of information I was looking for! Thanks! Big time! \$\endgroup\$
    – yhunz_19
    Feb 9, 2014 at 10:04
