A follow-up to What are the ratings of vintage Selenium Rectifier B20/16-2,4?
The photograph linked shows, in the red-box, a spiral wire on the transformer bodyspiral wire on the transformer body. What is the purpose of this?
p.s. I vaguely recall a similar (pardon my language!) contraption on top of a sub-station transformer - think it may have been at a Railway yard.
  • \$\begingroup\$ I think I fail to see the transformer .. can you zoom out a bit? \$\endgroup\$
    – jippie
    Feb 9, 2014 at 19:23
  • \$\begingroup\$ This is the top of the transformer. I'll get another photo, and post it. \$\endgroup\$
    – Everyone
    Feb 10, 2014 at 3:49
It's probably a hand-wound inrush/current limiting resistor.
Basically, it's a big, low-resistance power resistor used to limit the inrush current when the device is plugged in.
Since this is part of a battery charger, and not a device with significant internal capacitors, it's probably more to protect the rectifier in the case of an output short then limit inrush current.
It could be a home-made power resistor (made from something like Nichrome).
It shows like an "equipotential connection" for earth (PE). May there is some similar connection in the chassis or case.
