To start off I'm pretty new and have never used a LED strip before. I bought a meter of RGB LEDs off of ebay. The strip is based on the newer LPD8806 chip. I downloaded and tried to run the strandtest from adafruit's library. I can't seem to get it working correctly though. Any suggestions would be helpful.
Strip Wiring
Black  - Ground
Green  - Pin 3 On Arduino
Red    - 5v from ATX PSU
Blue   - Pin 2 On Arduino
Arduino Uno Wiring
gnd    - Shared Ground
Strip Wiring
Black - Ground
Your connection doesn't seem to be correct, I think you are following a wrong pinout.
Based on the designators of your provided image (viewed at the right side pads which are the same as the left side pads)
The pinout is:
Black: Data
Green: Clock
Red: 5v
Blue: Ground
Do you have the ground from the PSU connected to the ground of the arduino? If not, the strip will not work.
With a single meter of LPD 8806 you can run strandtest with the strip powered just by the arduino. I recommend getting that working before adding an external power supply.
