I am trying to use the cellular ram on the Nexys 4 FPGA development board. I am using Xilinx Vivado and would like a Microblaze soft core processor to be able to perform reads and writes. So far I have created the processor in a block design.
After much hunting through the internet I eventually found an external memory controller or EMC which I thought looked promising. How would I go about connecting the Ram up? I have created a HDL wrapper and tried connecting the ports of the EMC to the pins of the ram, however, there are more ports than I need. I can't find any examples of the Nexys 4 or for the Vivado EMC.
I also found that the Nexys 2 has an example of an onboard memory controller. I see that the part number is the same for the RAM. Would this be usable and how would I use it in conjunction with the Mircoblaze?
