I have two of these stereo jacks that I am planning on using to rewire some headphones that have had the original cable fail somewhere between the speaker and the end plug. Instead of bothering to fix the existing cable, I plan to replace the cable entirely but also give them the ability to have a removable cable. The replacement cable has 1x 3.5mm stereo plug on one end and 2x 2.5mm mono plugs on the other end.
What I'm not sure of is whether or not there is an optimal pole to resolder when using a mono plug in this (stereo) jack?
For anyone curious, the final product:
Final product
closed as off-topic by Leon Heller, Daniel Grillo, Dave Tweed, Matt Young, Chetan Bhargava Feb 12 '14 at 15:45
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – Leon Heller, Daniel Grillo, Dave Tweed, Matt Young, Chetan Bhargava
If this question can be reworded to fit the rules in the help center, please edit the question.
You should use the tip and sleeve contacts (1 and 3). The ring contact (2) will contact the sleeve on a mono plug.
  • \$\begingroup\$ For clarification, would it make a technical different if I soldered the ring and tip instead? \$\endgroup\$ – Michael Frank Feb 11 '14 at 23:34
    \$\begingroup\$ @MichaelFrank: ring and tip should work too, but it is normal practice to connect the shield or common lead to the sleeve. If you use the ring and tip, you may get unwanted effects if you happen to plug in a stereo cable. \$\endgroup\$ – Peter Bennett Feb 12 '14 at 0:26
