I have a very simple circuit, and I want to use a tri-color LED to indicate which 1 of 3 outputs is on. I currently have a design that works for a common cathode 4-pin LED. However, I have easier AND cheaper access to this function of LED with a common anode.
It has to be red, yellow, and green. Each output has to drive a separate 10Ω resistor, exactly as shown in the pics. Only 1 output is on at a time.
The picture on the left is common cathode, and works as intended. How can you change the picture on the right (common anode), in order to acheive the same result?
  • \$\begingroup\$ In the right-hand drawing, you could place R5 and RYG just to the left of the Green, Yellow, and Red power sources... (With R5 to GND, and the cathodes to the - supply terminals.) But maybe I'm misunderstanding something. \$\endgroup\$ Commented Feb 13, 2014 at 23:01
  • \$\begingroup\$ I am not able to physically connect anything to the negative side of the power supplies unfortunately. \$\endgroup\$
    – brett s
    Commented Feb 13, 2014 at 23:05
  • \$\begingroup\$ If you're talking about connecting the cathodes to +, that will not inhibit current flow through the LEDs. \$\endgroup\$
    – brett s
    Commented Feb 13, 2014 at 23:06
You could do this (resistor only shown for one channel). You could use a single ULN2003A in place of all the transistors and all the resistors except for the 500R, and that is precisely what I would suggest doing.
  • \$\begingroup\$ I am going to avoid adding components to the design if I can. Thanks for this thought though. If I absolutely have to, I'll wait for the common cathode LEDs to hit stock. \$\endgroup\$
    – brett s
    Commented Feb 13, 2014 at 23:02
If you don't want to use additional components then the only alternative I see is reversing the sources, assuming the load nature and what is shown as source allows this.
  • \$\begingroup\$ With this, what keeps V1 electrons from going to V2 or V3? \$\endgroup\$
    – brett s
    Commented Feb 14, 2014 at 22:03
  • \$\begingroup\$ @bretts The resistors. This has the same behaviour as the schematic you have posted. The source is just a voltage potential, it doesn't make a difference which polarity is common to the circuit. \$\endgroup\$
    – alexan_e
    Commented Feb 14, 2014 at 22:18
