Can someone please explain how to find the pin-out of a 5M80Z CPLD device. The documentation on this page shows the names of the pins but does not indicate the pin numbers.
I have not encountered this naming scheme before: http://www.altera.com/literature/lit-dp.jsp?category=MAX%205
Also I do not have ORCAD installed so using the .obj files is out of the question.
EDIT:
I just installed the demo version of ORCAD and I see this which is completely confusing:
So which is true now, the rightmost column on the pdf or the .olb file
  • \$\begingroup\$ It looks to me as though the pin numbers are the right-most column, what's the package for the device? That scheme is common with BGA packages and possibly others. \$\endgroup\$ – PeterJ Feb 16 '14 at 3:31
  • \$\begingroup\$ The package is TQFP-64 and the device is 5M80ZE64C5N. \$\endgroup\$ – Dimo Feb 16 '14 at 3:32
For the 5M80ZE64C5N if you look at Pin Information for the MAXV 5M80Z Device and scroll down to page 3 you'll see the pin numbers for the E64 devices in the right-most column.
  • \$\begingroup\$ Thanks, I missed this , just to make sure is M64 the same as E64, both are TQFP-64 \$\endgroup\$ – Dimo Feb 16 '14 at 3:40
  • \$\begingroup\$ It looks like the M64 is a BGA so the different numering scheme makes sense: uk.farnell.com/altera/5m80zm64c5n/cpld-max-v-80-le-64mbga/dp/… \$\endgroup\$ – PeterJ Feb 16 '14 at 3:42
  • \$\begingroup\$ I was looking for the pinout of the TQFP-64 part. How do I make sure that A1 is pin 1 and and B1 is pin2. \$\endgroup\$ – Dimo Feb 16 '14 at 3:45
    \$\begingroup\$ The A1 etc is for the BGA part, if you look at page 3 onwards where it says E64 you'll see the numbers are between 1 and 64. \$\endgroup\$ – PeterJ Feb 16 '14 at 3:47
