No, you cannot "just" anything with a transformer, until you are sure about the make-up of the secondary windings.
For example a 18-0-18 make-up, which is common in transformers for lower power amplifiers, means it has 2 windings of 18V, but they are already put in series inside the transformer. Yet again, if you have {18V} {18V} as separate windings, it is not uncommon to have two wires of the same colour for each winding. If you want to put them in parallel you will need to make sure you connect the right two wire to each other. If you connect them in reverse your transformer will see a very strong short-circuit and 1. consume a lot of power with no output, 2. eventually burn out.
Also be aware that a transformer has no "plus" or "minus". What comes out of the transformer is an AC voltage, meaning it goes from + on one wire and - on the other, to the other way around at 50 to 60 times per second. LEDs don't like reverse voltage at all. So connecting an AC to a LED will always degrade its lifespan, even if the AC voltage is under its breakdown limit.
So you need to rectify the AC voltage. Some care may have to be taken by not taking the full 0.83A as well, but with design margins on the transformer, that's probably less important.
If you just rectify your LED will still blink. If you want to minimize that, the schematic below is the safest bet. If you know what's going on with the transformer you can save on one rectifier by combining the windings before rectifying, assuming they are exactly the same otherwise. If you are not sure, just use the two rectifiers to be absolutely sure you don't make mistakes. The chosen capacitor gives reduced effect on the blinking, but does increase the effective DC voltage. In this case by about a factor 1.33. If you double the capacitor the blinking will be gone entirely and the effective DC voltage will be 1.4 times the AC voltage.
So as drawn: Vdc = 18V * 1.33 = 23.9V (with load!, without load it's the same as the next one!)
With double capacitance: Vdc = 18V * 1.4 = 25.2V
