I have a car cigarette extension cord with a USB out on it as well. The USB out though will not charge my phone, which is a bit annoying. I had a look at the circuit inside in the device and it looked something like this:
I'm guessing the reason the phone won't charge is the 78L05 chip is only rated for 100mA. Therefore I was thinking of changing it to a 7805 chip, which is rated for 1A. Would this idea stand up to my reasoning? Or am I likely to damage any equipment I connect if I go down this root?
Also, if I go about this, will I also need to do something with the capacitor and the resistor on the board?
Edit:
Thanks for all the answers.
I didn't think of the heating problems I might have in my scenario above.
Its looking like the best solution for the device is the one Nick Alexeev gave below if I'm going to stick with the device I have.
I have also changed the diagram above as the resistor is actually 360 ohm.
Also, I am including a image of the device itself below as requested to show exactly what I was talking about.
