I am using a Lego DC motor with a 9V battery which can provide up to 1A of current. I called Lego support and they said the motor draws 300mA of current. What does that mean? If I plug the motor to the battery will it use 300mA of current or will it use as much as my battery can provide and damage itself?
I know a motor has an internal resistance that's why I make this question: if is has na internal resistance it can control the amount of current that will consume without any external resistor, right? Am I right?
