After enough YouTubing and self educating, I decided to take the plunge and purchase a soldering iron. It took me two attempts (apparently the cable of the charger that has the grey dashes on it is the hot side and not the ground), but I managed to solder an old 12v phone charger to a 120mm case fan used for a computer. Everything wrapped up and it appears to work okay in my homemade keezer. Unfortunately though, as large as my keezer is (5 taps worth), one 120mm fan may not be enough to circulate the cold air throughout the entire chest freezer. My thoughts were to add a second fan, but don't want to have two power cables leading out if possible.
What would happen if I soldered both fans to the same, single 12v phone charger? What about more than two? Would the fans run at the same RPM or would they run at a lesser speed? Are there any issues with this I may encounter past potentially reduced RPMs if that is in fact the result? Should I just plan to use separate identical power sources to power however many fans necessary? Thanks for the help!
