Recently on a book i came across a problem-
Here when calculating the current flow through the diode they didn't consider the voltage drop across the diode.If it is correct then what am i missing?
From the question:
Assume the diode to be ideal
There is no voltage drop across ideal diodes.
Since ideal diode has no voltage drop and it is forward biased, it can be considered as a short. Thus R2 is shorted and the current flowing will be just : I = V/R1.
