As people have commented, "best way" is subjective, or at least depends on your requirements and priorities.
I will suggest a few approaches here, and give some pros and cons for each:
ADC method
In the comments, Dave Tweed suggests a circuit like the following:
Where "VM1" represents the single required pin of your ADC. Obviously, the resistance values and current are just sample values, and should be scaled to your specifications.
This circuits main advantage is that it only uses a single pin on your MCU. However, it has a few disadvantages:
- It will produce a constant power drain. This can be mitigated somewhat by only turning on the current when you wish to measure the buttons, but this would require a second MCU pin.
- It requires a constant current source, giving you at least a few extra components, extra cost, and extra power use.
- Depending on the number of buttons you have, it can be error-prone, especially if the resistances drift with temperature, or if the constant current source is non-ideal. Careful design can probably solve these issues, and allow you to detect a large amount of buttons with the 10-bit ADC in the ATtiny85.
A note: you can also design this sort of circuit without needing a constant current source by simply using a resistor in place of "I1". The current will now vary, meaning that the ADC reading is no-longer linear with the resistance, but using the correct threshold-values in the software will still enable you to detect the configuration, albeit with reduced noise-margin.
Shift register
Another, maybe more standard method, would be to use a paralell-in serial-out shift register, such as the 74HC165. This will allow you to sample a practically unlimited number of buttons, with only 3 MCU pins (SHIFT/LOAD, QH [serial out], and CLOCK, in the datasheet linked).
This has the advantage of being fully digital, leaving a minimum amount of room for errors due to accuracy. However, you will need a (large) extra component for every eight buttons (each with associated cost and power draw). Additionally, you will need a software routine to latch the button states and read the data back serially, although this can probably still be done quicker than taking an ADC measurement.
Row/Column scanning
Row/Column scanning is a very common solution. You arrange your switches in a grid, and have one wire for each column, and one for each row. Then the MCU will apply a signal to each row in sequence, and monitor which columns the signal appears on.
This method is common, simple, and, if you include a diode with each switch, able to detect any combination of keys. However, with only three pins available, it is of limited use.
Charlieplexing
A variant of row/column scan is to use charlieplexing. This technique is most commonly used for controlling LEDs, but can also be used for inputs (using the internal pull-up resistors). The circuit design and software method for reading varies between configuration, depending on number of buttons, number of pins, and the required number of simultanious buttons, so I won't go into specific circuits.
Advantages include no ADC, minimal quiescent current draw, and a small number of pins. Disadvantages include high complexity (both SW and HW), and many extra passive components.
Final note
There are more considerations that might be relevant, such as ability to detect switches that has failed open or closed, ability for the MCU to trigger of interrupts, and how debouncing is handled.
best way
means different thing to different people ... what if someone's best way is your worst way? \$\endgroup\$
