We designed a power board that can deliver 5V and 3V3. Those two voltages are provided by two boost/buck converters that can deliver 3A each. The board accepts power from a USB-C socket which is connected to a cellphone charger that can output 3A with a USB-C cable.
Currently, the only pins I'm using on USB-C is GND and VBUS. What I'm realizing now is the USB-C chargers that are for cellphones are able to negotiate the AMPs provided to whatever is being charged but I didn't setup this negotiation on our power board. I'm wondering if I'm just getting the default 500mA, or would I get the full 3A from the wall charger?
I haven't tested this yet, and I will, but I'm more interested to know about the process of negotiating the current draw from the USB-C wall charger.
An example would be this charger which can output 5V 3A or 9V 2.3A: https://www.amazon.ca/Charger-2-Pack-Super-Charging-Samsung/dp/B096PHS41G/ref=sr_1_89?crid=JIHPL6OPSI97&keywords=usb-c+charger+3A&qid=1646953774&refinements=p_85%3A5690392011%2Cp_72%3A11192170011&rnid=11192166011&rps=1&sprefix=usb-c+charger+3a%2Caps%2C75&sr=8-89
