I am building my own thermal couplings for a experiment I am doing at home. I want to build a very small thermal generator with them. At each contact point does the amount of surface area involved in making contact affect the amount of electricity being generated?
\$\begingroup\$ Thermal inertia will influence it. \$\endgroup\$– jippieCommented May 10, 2013 at 20:12
\$\begingroup\$ Not enough detail provided and your question is ambiguous. Are you making your own TEG cells or using a commercial device. Voltage generated depends on temperature but electrical energy is related to heat flow so as small contact area limits thermal energy flow. it will also affect power output. \$\endgroup\$– Russell McMahon ♦Commented May 10, 2013 at 20:42
\$\begingroup\$ im making my own thermal pile for electric generation, my goal is 250 milliamps from the whole thermal pile, i was wondering if i flattened the wires to increase contact area, if it would improve efficacy \$\endgroup\$– JohnCommented May 10, 2013 at 21:18
Thermopiles are not well suited to generating large amounts of current, typically only a few tens of milliamps. They also do not generate much voltage per thermocouple hence you have to put them in series to boost the voltage. even with this you need to generate the highest possible thermal difference from couple to couple to get anything out of them. Still it would be possible to generate enough to power low wattage loads. You could buy a thermoelectric cooler module and clamp it between a cold plate and a hot plate and it would generate some power at its leads. Those devices would be optimum for many applications. Don't expect to get much out of a string of thermocouple wires all twisted together though. The short answer is to improve the thermal coupling to the junction itself.
At each contact point, the area will affect the resistance. This will not affect the open-circuit voltage available, but it will affect the maximum current output.
So for high current you need large contact area and large diameter wires to minimise resistance and maximise the current and therefore power available. Do you need to flatten the wires? Well, as long as the contact resistance is suitably far below the wire resistance, there is little to be gained from reducing it further.
250 ma sounds feasible : but at what voltage and what temperature differential? Gas boilers in the UK use the current from a single thermocouple at dull red heat to hold a solenoid gas valve open. This cuts off the gas if the pilot flame dies out. I don't know the actual operating current but it must be quite significant to power the solenoid.
The problem with thermoelectric generators is that increasing the wire diameter also minimises the thermal resistance between hot and cold sides - as you increase the useful power output you also increase the wasted power (heat directly conducted from hot to cold) - the efficiency remains constant at about 1% to 2%, dictated by the thermoelectric potential, and the ratio of thermal to electrical resistance.
(Unless you have access to exotic metals like tellurium - I forget exactly, but suitably expensive materials can give 5% or even 8%)
\$\begingroup\$ 5 volts, and im thinking of using a burning coal as the power source \$\endgroup\$– JohnCommented May 11, 2013 at 20:21
\$\begingroup\$ on the cold side i am thinking of using a coolant \$\endgroup\$– JohnCommented May 11, 2013 at 20:22
\$\begingroup\$ i have a bottle of non-conductive coolant used to cool CPUs \$\endgroup\$– JohnCommented May 11, 2013 at 20:23
