I have a little bluetooth FM transmitter that uses a single button that you press and hold to turn the device on, press and hold to turn the device off, and press once to change the FM station it broadcasts to. Is there any simple way to alter a circuit like this to be "always on" and essentially short circuit the switch?
If it were some sort of toggle push button switch this would be simple, but seeing as it's a simple momentary push button used for other things, I have no idea where to even begin.
