I own a Rail track master and it needs two pull type continuous solenoids. The age of this machine is from the 1950's and both of the previous solenoids were unidentifiable. These solenoids operate the systems' sand boxes for dispersing sand on the track for the machine gain traction.
I need help with calculating/selecting the right type of solenoid. The specs that I have are:
- 12 volt system,
- pull in solenoid,
- 1-3 inches stroke,
- continuous cycle (energized by momentary electrical switch),
- Cylindrical shape solenoid body,
- watts needed unknown,
- 10-12 gauge wire will be used for install.
