Electrical newbie here. I'm trying to get understanding how is resistance involved with power dissipation (ohmic losses, eg. heating). Primarily I'm looking at Electromagnet coil, it says the losses are \$P=I^2R\$, so reducing resistance R reduces heating power loss P, which sounds reasonable as it comes from (I assume):
\$P=UI\$ and Ohm's law \$I=\frac{U}{R}\$ (and thus \$U=IR\$), so by substituting U we get \$P=UI=(IR)I=I^2R\$
But, if one substitutes I instead, he'd get \$P=UI=U(\frac{U}{R})=\frac{U^2}{R}\$. Which seems to tell me, that with stable voltage source U one would get lower power loss (heating) with increased resistance R!
Which unfortunately also makes sense to me from empiric point of view: If I connect very high value resistor (or its equivalent - a veeery long wire) across 230V line, it would only heat a little, and I put very low value resistor across 230V line, it would heat so much it would burn (which I guess is what fuses do for living). (replace 230V AC with 9V DC battery if AC/DC distinction matters here)
So I guess I'm missing something basic - would increasing resistance reduce or increase power losses? Or is wire in "put it in 230V socket" example behaving completely different that wire in electromagnet example (and if so, why?)
