Edit: The person operating the catheter will be wearing latex gloves. The only human tissue the catheter would touch would be that of the patient. Also, to clear up some confusion about what exactly we're trying to, I included a picture below. The catheter is not threading through the dura, but outside of it.
So, we're designing what is essentially an operation-type game, with one major exception. Whereas a normal operation game has both the tweezers and the metal rims attached to the battery.
Ours, however, is intended to function as a medical training tool. An actual stainless steel catheter or needle will be used, and we obviously can't hook that up to a battery. Whenever the metal touches this long tube (your spinal cord, if you like the bio stuff), we're going to have an LED light up.
All of the information we can find about completing a circuit by touching something to it involves that something hitting in a precise spot to close the circuit. But we need to trigger the LED by touching ANY part of the tube.
We're planning on wrapping the tube in copper tape, in bands separated by rubber. Our output is a row of LED lights, indicating the generally area touched (based on the bands).
Our only idea so far, in terms of circuit design, is to design a floating circuit and then use the catheter tip as the grounding element. Once grounded, the circuit will activate and turn on the LED. Any idea if this will work or not? Or any other ideas? The only thing that cannot be changed is the medical grade stainless steel of the catheter/needle- all other materials are flexible.
Thanks!
