I'd like to use MX-FS-03V 433MHz transmitter together with a Raspberry Pi (RPi). The Raspberry Pi's outputs have 3.3V, but the MX-FS-03V operates on 3.5-12V (the higher the voltage the higher the transmission distance).
In my understanding, when connecting the MX-FS-03V's VCC to 12V, the DATA input pin must use the same voltage. Is this correct?
The RPi provides 3.3V and 5V, but no 12V. What would be the most simple way to let the MX-FS-03V operate on 12V?
