I'm trying to solder a few capacitor grounds to a small motor body. I'm using 60/40 flux core solder and I cannot get the solder to stick to the body of the motor! Is there some secret way of doing this?
2\$\begingroup\$ Scrape the coating from the steel. \$\endgroup\$– Leon HellerCommented Mar 10, 2015 at 7:35
\$\begingroup\$ How heavy is the motor? Soldering to a large mass of metal (like a transformer, a motor, or an electromagnet, or the actual metal case of the motor) can take a surprisingly long time to get everything hot enough to flow the solder. And likewise it can take a few minutes to cool enough to avoid cold solder joint failure, so it's important to make the setup mechanically stable before applying the heat. \$\endgroup\$– MarkUCommented Mar 10, 2015 at 8:40
\$\begingroup\$ What do you mean mechanically stable? \$\endgroup\$– Michael RaderCommented Mar 10, 2015 at 9:05
1 Answer
There are two problems:
Heat
A motor is a large piece of metal, so the heat applied to one spot will quickly spread to the large volume. As you don't want to heat the complete motor to soldering temperature, you have to apply the heat as fast as possible. Choose a high power solder iron or at least set your iron to the highest possible temperature. I also prefer a small torch. (But be careful, it can easily overheat your motor and damage it)
As said in the comments, it also takes long to cool down, so make sure that the motor and the wire don't move while the tins is not yet solid. Holding by hand is not a good idea.
Material
Solder/flux used for electronics works well for metals found in electronics, e.g. copper, tin, gold, but also zinc.
On the other side, iron can not be soldered that easy. The tin will roll off just like water from a waxed surface. To solder iron, solder tins with a high fraction of lead are used, as well as flux based on zinc-chloride. In my experience, electronics solder tin and zinc-chloride based flux usually work fine for a reasonable conductive connection. The special solder tins for iron also require a higher solder temperature. Note that zinc-chloride is quite aggressive and you should carefully remove it after soldering.
However, many iron parts have a zinc coating and can be soldered without problem. But parts are often also coated with some painting, e.g. a thin yellow-greenish painting to prevent corrosion, and of course, you have remove it before painting. May be, you manage to remove the painting but keep a zinc coating.
There are also other metals like aluminum which are quite impossible to solder.
\$\begingroup\$ Here are some tips for soldering aluminium app.aws.org/wj/2004/02/046 \$\endgroup\$– KalleMPCommented Aug 4, 2015 at 10:07
