I am not sure If I have phrased the question right but if not please correct me
I want to know when Accuracy Parts per Million mentioned in the datasheet of voltage reference they say for example 5 ppm/c, which from my understanding, for every degree increased a 5 parts per million of the output voltage will increase
OK, but what is the base temperature that I should consider to calculate the drift ? is it the initial temp. when the Vref began its work, or the ambient temp which would be 25 degrees or the temp. which the manufacturer toke his original measurement in his laboratories ??
I want to calculate the voltage ref. drift that happens because of the temp. changes and after that try to make compensation in the software, it is still an idea I don't know if it is good or not but it worth trying it
