It could mean:
- "Short-circuit", as in connected to ground as you have found by experimentation. This is not normal terminology though.
- "Short-duration", as in "a brief connection of the trigger to GND will start the timer. Normally a hundredth of a second would be adequate for this so I don't know why they're looking for 1 - 3 s.
You'll have to do more experimentation. I suggest:
- Set up a 10 s delay.
- See what happens with a 0.5 s trigger (to GND).
- See what happens with a 3 s trigger.
- See what happens with a 5 s trigger.
- See what happens if you hold the trigger on indefinitely.
You should be able to figure out from these tests:
- Whether the trigger duration matters.
- Whether the load switches immediately on trigger.
- Does the load switch off when trigger is removed.
- Does the load stay on if the trigger is held or does it switch off until the trigger turns off and on again.
Voltage does change with the sensor, I have 4.85v with the light on
and 2.15v with light off but that doesn't trigger.
The problem is that your sensor is giving an analog output. Your trigger requires a digital signal, on / off.
Figure 1. Potentiometer trigger test. Figure 2. Diode voltage dropper.
It seems as though your sensor output voltage swing is not adequate to trigger. You need to do some experiments:
- If you have a potentiometer you could test to see how low the voltage has to go before the trigger works. Hook it up as shown in Figure 1 and monitor the voltage on the input.
- Then, if you have a few diodes, you could try the circuit in Figure 2. Each diode will subtract 0.6 to 0.7 V from the sensor signal and, hopefully, drop it below the threshold voltage for the trigger. Again use your multimeter to check what's going on.
