I am having Creative Inspire M2600 pc speaker. I need to connect it to a dvd player which having output of 40w-40w and not having a 3.5 mm out. Can i connect the dvd output to a 3.5 mm female jack and plug the pc speaker's 3.5mm male to that female port. Is it possible? If not, please let me know how can it possible.
\$\begingroup\$ What DVD player only has amplified speaker outputs. Picture and model number \$\endgroup\$– PasserbyCommented Apr 21, 2017 at 18:08
\$\begingroup\$ Its a local brand dvd player \$\endgroup\$– KIRAN K JCommented Apr 21, 2017 at 21:10
\$\begingroup\$ If the DVD player has a headphone jack, you could connect the Creative speaker system to that. \$\endgroup\$– Peter BennettCommented Apr 21, 2017 at 22:26
\$\begingroup\$ No headphone jacks. Only LR out \$\endgroup\$– KIRAN K JCommented Apr 22, 2017 at 3:15
No, you can't connect them directly. Outputs designed to drive 40W into a pair of speakers can exceed 20V or so and damage the line level input of your M2600, which expects a signal of around 1V or so. In addition, both speaker terminals may be floating with respect to ground and the M2600 will expect one of them to be at ground, so connecting directly may damage the outputs of your DVD player.
But there is a solution. This used to be a very common issue in car audio systems where people wanted to add amplifiers but only had speaker outputs to connect them to (many head units nowadays have pre-amp outputs for this). You can use a speaker to line level converter such as this one:
Here's the link to this one but I'm sure eBay is full of alternatives, just search for speaker to line level converter. For this one you would need an adaptor cable to connect two PCA phono connectors to a stereo 3.5" jack, but other versions may have the correct connector already.
\$\begingroup\$ Does it need dc power supply? Is it have 3.5 mm output? \$\endgroup\$ Commented Apr 22, 2017 at 15:57
\$\begingroup\$ The one in the link does need power, according to the link anything from 9 to 16V DC. I'm guessing it's because it has adjustable gain, but it should be possible to do the same job with a passive device that won't need power. I'm not suggesting this is the one you should use, it's just an example of the type of device and no, it doesn't have 3.5mm output so you'd need an adaptor cable. \$\endgroup\$– FinbarrCommented Apr 23, 2017 at 12:42
\$\begingroup\$ I fitted such a device which does not need extra power. Its working now. But getting engine noise. Any solution? \$\endgroup\$ Commented May 8, 2017 at 5:03
It appears, from what I can see on the Creative website, that the Inspire M2600 system is not a bare speaker, but includes amplifiers - since it is described as a "pc speaker", it will accept the line level audio output from a computer, iPad, or similar device. You should not connect it directly to the 40 Watt speaker output of your DVD player.
