I want a power a homemade robot that uses an arduino and 4 small dc motors and a few sensors. Ive used pp3 energizer 9v batteries to power it in the past and they worked well, i used 9v again after they died but a different brand and learnt that not every 9v is the same as it wasnt strong enough for the bot to make turns. Why do different batteries of the same voltage have different results and some are stronger than others? is it because of internal resistance because 9v use the same chemicals i couldve sworn?
I want to use a nimh rc battery now that will last long and be strong enough for the robot and was wondering if amp hours means capacity and if was to use 2000mah battery, it wouldnt damage the arduino. I have my eyes set on this battery and charger and was wondering if they would work together too?
