Are clamp meters as accurate as multimeters?
Could I replace a multimeter with a clamp meter?
What can clamp meters do that multimeters can't?
What can multimeters do that clamp meters cant?
Clamp meters are good for measuring higher currents. Standard multimeters can typically measure current but require breaking the circuit and are good for measuring amplitudes less than an amp ( milli or micro amps). Some clamp meters have almost as many features and ranges beyond current by attaching leads- allowing you to measure voltage and ohms. Make a list of your requirements and then compare your list to meter specifications and capabilities. The only defining requirement for me is if I need to measure milliamperes, which typically clamp meters don’t have good resolution and standard multimeters are better suited for.
  • \$\begingroup\$ There are clamp on mA meters with exceptional resolution. They are typically used for current-loop process instrumentation measurements. \$\endgroup\$
    – R Drast
    Commented Sep 27, 2017 at 10:08
Clamp meters can only detect change in current in a conductor without making electrical contact or needing to put it in series with the load. They can also detect common mode current in a pair of conductors (like a ground fault).
That's all.
Which means it is not a substitute for a multimeter at all.
In DC mode they will drift because it integrates all current changes over time which naturally accumulates errors.
