A screw terminal distribution block is shown below:
A three phase motor driver manual specifies "connector voltage" and current for mains voltage connections for the motor. They specify current as 30A and voltage as 1000V.
Imagine I use a screw terminal block as a connector as following:
1-) What does 1000V voltage rating mean for a connector or a terminal block? Is that something to do with isolation break down voltage between consequent terminals?
2-) The rms voltage difference between R and S is 230*sqrt(3) = 400V rms. This means 560V amplitude and this is half the 1kV requirement. Can 1000V requirement be about transients?
3-) What if I connect R S and T further apart for example every three terminals(not adjacent), would I increase isolation voltage?
