I'm confused about whether zener is on or off due to not being able to know voltage on V0. I tried to find by applying KCL & KVL, but current on the diode (Id) and the resistor (Ir) is not equal to each other. I'm using the shockley diode equation.(Id=Is(e^(Vd/Vt))). This current source being connected to zener diode instead of a voltage source makes something complicated. Which way should I follow to find V0? Hope one can give me a trick.
Thanks in advance.
