I am stuck with calculating the peak current through the inductor in a boost converter. Can you please check if I am right?
Ipeak = (Vmax / R2) = 18 / 1000 = 0.018 A. So, my peak current through the inductor is just 18 mA? Am I doing it correctly?
If this is correct, how will I account for the Vce drop inside the pin1 and pin2 of the IC?
The Darlington transistor inside the IC is just like a normal transistor. I have added two transistors outside the IC instead of using the Darlington switch in the IC for thermal purposes.
Can you please help me with the calculation of Vswce and Ipeak? The calculation of Vswce is not mentioned in the datasheet.
The calculation of Ipeak is mentioned in the datasheet, but is my approach of calculating the peak current through the inductor right?
My circuit
From Figure 4. Block Diagram in the datasheet, you can see pin 6 is compared with pin 7 of the IC.
Note that the + input of the comparator lies 200mV lower than Vcc.
When pin 7 becomes lower than (Vcc-200mV) the peak detection will be activated (and so, the Darlington transistor will be disabled).
From your posted schematic, the (peak) current through the inductor causes a voltage drop across R1.
This voltage drop is divided by resistors R2 and R3.
So, the voltage on pin 7 will be:
\begin{equation}(V_{cc} - I * R_1 ) * R_3 / (R_2+R_3)\end{equation}
The peak detection will be activated when \begin{equation} V_{cc} * R_3/(R_2+R_3) - I * R_1 *R_3/(R_2+R_3) < V_{cc}-200mV \end{equation} Note that this depends on the current through the inductor as well as the applied voltage Vcc.
R3 is unclear to me, but 0M18 = 180K makes sense, and pick Vcc = 15V \begin{eqnarray*} 15V * 180/181 - I * 0.082E * 180/181 &<& 14.8V\\ 14.917V - I * 0.082E * 180/181 &<& 14.8V\\ 117mV &<& I * 0.082E * 180/181\\ 118mV &<& I * 0.082E\\ 118mV / 0.082E &<& I\\ I &>& 1.44A \\ \end{eqnarray*} So, max peak cuurent through inductor is 1.44 A
When e.g. Vcc = 10V, the same circuit limits the current to 1.78 A
  • \$\begingroup\$ Thank you very much. Now, I clearly understand this calculation and working. Can you please help with Vswce? How do I calculate Vswce? It is not given in datasheet. \$\endgroup\$
    – Freshman
    Commented Jan 29, 2019 at 4:39
  • \$\begingroup\$ Why would you want to know Vswce? \$\endgroup\$
    – Huisman
    Commented Jan 29, 2019 at 10:45
  • \$\begingroup\$ In the datasheet of NCV3063, Fig.15 we need to calculate Vswce to find Ton/Toff. \$\endgroup\$
    – Freshman
    Commented Jan 29, 2019 at 10:55
  • \$\begingroup\$ It is given in the datasheet, page 5, especially Figure 9, but also in Figures 7,8 and 10. \$\endgroup\$
    – Huisman
    Commented Jan 29, 2019 at 11:20
  • \$\begingroup\$ Yes. But I am not able to understand. Please explain how to calculate Vswce like how you clearly explained Ipeak calculation. Please. Sorry for the trouble \$\endgroup\$
    – Freshman
    Commented Jan 29, 2019 at 11:23
-1
In a boost converter the inductor peak current (relevant for saturation) is inductor average current plus maximum ripple. Your modulation index is
\$d = 1 - \frac{V_{IN}}{V_{OUT}}\$
The average inductor current, depending on your specific load \$I_{OUT}\$, is
\$I_{L,avg} = \frac{I_{OUT}}{1-d}\$
The ripple current is (depending on your switching frequency \$f\$)
\$\Delta I_{L,peak-peak} = \frac{V_{IN}}{L} \cdot \frac{d}{f}\$
Finally we get for continuous conduction mode
\$I_{L,peak} = I_{L,avg} + \frac{1}{2} \Delta I_{L,peak-peak}\$
while for discontinuous conduction mode the maximum current is simply
\$I_{L,peak} = \Delta I_{L,peak-peak}\$
Since a range of input voltage is given in your schematics, you will at least have to check for 8 V and 18 V which gives the higher inductor peak current.
Your maximum input current is specified as 0.6 A, so the maximum inductor peak current will be higher than this.
  • \$\begingroup\$ Please correct me if I am wrong, but the peak inductor does not need to be summed up with the average current inductor. You formula of the peak-to-peak is valid, but considers already the entire slope from 0A to Ipeak as the worse case scenario. Double check with a drawing and with, for example, an app note like SLVA797. \$\endgroup\$
    – thexeno
    Commented Jan 19, 2022 at 11:39
    \$\begingroup\$ In continuous modulation which I assumed (maybe I was wrong here) you have to add the average current. In discontinuous modulation you must not. \$\endgroup\$
    – UweD
    Commented Jan 19, 2022 at 14:14
  • \$\begingroup\$ Thanks for clarify. I assume by modulation index you mean duty cycle D. So making a calculation, means than in a classical boost, imposing a maximum inductor (absolute) peak current, with higher input voltages, the converter can output more current, with lower p-to-p current. Makes sense? \$\endgroup\$
    – thexeno
    Commented Jan 19, 2022 at 16:43
  • \$\begingroup\$ (Seems you need to edit the question to put the +1) \$\endgroup\$
    – thexeno
    Commented Jan 19, 2022 at 17:28
