Hello I am planning to use LT1785 UART-RS484 transceiver. I will use that chip in order to get RS485 data and convert it to UART signal. So I have read the datasheet but I couldn't be sure. It says
A logic low on RE enables normal operation of the receiver output RO. A logic high level at RE places the receiver output pin RO into a high impedance state.
I shorted the RE/DE pins because I will only use this chip to receive RS-485 signal and convert it to UART. So my questions
- Can I directly connect shorted RE/DE pin to the ground?
- In the absolute maximum ratings Vcc is given 18V. Does that mean I can supply this chip with any voltage up to 18 V? In case of 5V supply voltage, will this chip work?
