My question is based on the attached picture of a diode which says SX DG but I can not find this diode. The diode is taken from PoE 63v part of IP camera attached with MB6s ke47enter image description here
SXDG SX DG
  • \$\begingroup\$ on diode SX DG are written \$\endgroup\$
    – ir s
    Commented Jun 15, 2019 at 6:37
Maybe? :SMBJ58CA littlefuse transint supressor diode in DO-214AA package.
You should specify where did you take those elements from. What is their theoretical purpose.
  • \$\begingroup\$ Not likely. SMBJ XXX C A diodes have a cathode band and a Littelfuse logo on them. \$\endgroup\$
    – Huisman
    Commented Jun 15, 2019 at 9:46
    \$\begingroup\$ @Huisman bi-directional wouldn't have a cathode band, It could any other manufacturer making equivalent. \$\endgroup\$ Commented Jun 15, 2019 at 12:05
    \$\begingroup\$ looks like taken out from right side of PCBA \$\endgroup\$
    – Curious KP
    Commented Sep 18, 2020 at 5:07
  • \$\begingroup\$ Agreed. The brand is not Littelfuse, but dozens of companies second-source these parts, and many use the same codes/markings; the placement near what appear to be FWBs, and the voltage being realistic for a PoE application, gives further confidence. \$\endgroup\$ Commented Apr 19 at 8:55
