enter image description here Hello, I bought a mp5 player for my car and I didn't find the 20 pin cable for this player. My question is if I could replace it by Dupont jumper wires as the picture shows
    \$\begingroup\$ I doubt those jumper wires have an automotive-grade vibration spec ... I'd be concerned that they'd fall out over time. \$\endgroup\$
    – brhans
    Commented Sep 25, 2019 at 19:53
  • \$\begingroup\$ It looks like an old floppy ribbon cable at this end. \$\endgroup\$
    – D.A.S.
    Commented Sep 25, 2019 at 22:00
    \$\begingroup\$ Is there such a thing as mp5? \$\endgroup\$
    – Hearth
    Commented Sep 25, 2019 at 22:51
    \$\begingroup\$ i think that an MP5 is a weapon \$\endgroup\$
    – jsotola
    Commented Sep 26, 2019 at 0:45
  • \$\begingroup\$ MP5 is a format, apparently. Also a sub machine gun. The most cost effective weapon in Counterstrike, but I prefer the finality of the equally economic pump shotgun. \$\endgroup\$
    – DKNguyen
    Commented Sep 26, 2019 at 1:04
As said by brhans, the Dupont cable is most likely going to fall out due to the vibrations made by a car. One thing you could use to mitigate this problem is to install a proper cable connector. One of these could work: Connector
If you're not willing to use a proper cable connector though, you could always hot glue the Dupont connectors to wherever they need to go. This can give you some protection from vibrations but may not be the best solution.
