I want to sense position along a slightly curved metal rod (length 100mm, diameter 5mm) for a project. For the wiper element, I'll be using steel wire of diameter 0.3mm, the length of which runs perpendicularly along the rod's length. I've tried wire-wound techniques, but they pose issues for my project such as durability and a lack of surface smoothness. I'm thinking of creating a new rod with the same dimensions made out of a material that would be durable enough to withstand heavy usage. I was looking at carbon based plastic materials since they offer high resistance, but am open for advice. I want to be able to mould the material into the shape of the rod in question.
Is this a good way to go, and if yes, what material would suit best?
