Preface, I'm a plant engineer and my background is mechanical engineering. My current project requires me to find some pressure sensors for my compressed air lines and this is a pretty new territory for me. These sensors will be located in a dry room, same room as our compressors and PLC; so no running long wires or having to worry about water. I'm pretty set with the specifications of the sensors, now what I'm stuck with is choosing between two connection types. As an ME I'm not terribly familiar with the different connection types.
The site I'm looking at offers two connectors:
- a DIN 43650 (DIN 175301-803C) connector
- an M12 Connector
So my questions are:
What would be the advantages/disadvantages of both? From what I've found, M12 is better for harsher environments, like from a washdown; but other sites mention that the DIN connector is also capable of sealing from water. It also seems to me that M12 is more secure due to screw connection. How does the DIN connector keeps itself secure?
For my application, does it matter which one I choose?
Are there any effects to the electrical signal between the sensor and my PLC when choosing one connector to another? I'm using current to sense the pressure.
(bonus) What other connection options are commonly used among electrical engineers for connecting small sensors and actuators?
