For a prototype project I'm building, I need to select a motor. I'm not familiar with different types of motors, so I have been trying to do some research. However, most of the stuff I have been able to find has been about low-power motors (e.g. handheld devices, models, etc) motors or about high-power motors (e.g. car winches). I haven't been able to find much information (or sources) for medium-power ("human scale") motors and I've been getting confused by the different types (e.g. AC vs DC, series wound, permanent magnet, etc) and the different trade-offs for these within this power range.
Essentially, my key requirements are:
- To pull a cable in (and let it out) against a force of up to around 2 kN at speeds of up to around 0.5 m/s.
- Within that force range, the line speed should NOT vary with the applied force.
- To control the direction (in/out), speed of the motor and the position of the cable with a computer.
The machine will be fixed in place, so it can be mains powered. The total distance the cable will move will only be a few meters. The machine can also be quite large, so the cable could be spooled from a drum/wheel with any radius up to about a max of 0.5 m (I was considering using a bicycle wheel). So the max torque needed of the motor would be something like 1 kNm (with a 0.5 m drum/wheel) to 200 Nm (with a 10 cm drum/wheel).
If anyone has an advice to offer on what type of motor would be suitable for this application and where (ideally in Europe) it could be sourced from, I would be most grateful.
