I want to use a 12V 15A switching power supply for a 12V 10A DC motor which has about 9A start current and 6A no load current, I also want to add a push button switch for on and off function to use it and by that, each time motor stops it’s gonna draw huge current from supply and I’m going to add some caps on to the curcuit; so my questions are:
- will this high amount of start current damage the switching power supply with those repeatedly on and off times?
- with numerous on and offs will the motor get damaged in long time or be hot more soon than normal using?
- if we use cap to provide srarting current, what size and voltage?
- where to add the switch? closer to supply or the motor? (in the case we use capacitor/s)
thanks
