I had a question about trying to get a solenoid with 20 ohms resistance to power up from a 24V Power supply limited to 0.5 amps.
I tried connecting a 10 ohm resistor in series, to drop the driving voltage to 16V, but I ended up burning the resistor. The valve did work properly before the resistor burned up though. Is there a higher amp resistor part-number search I can get somewhere?
I know I should use a relay and drive this as an alternate circuit, but this is a field application, and I don't have the resources to create even a tiny panel atm... Any help would be appreciated, the goal is to get it working :D
The application is driving a valve which is connected to the SMC EX600 valve pack DYPB output card. Manual here.
