enter image description here Not being an electronics professional but face the following problem I hope you can help me. I would like to estimate the losses due to an impedance mismatch of connector used in wall-crossing of a coaxial transmission line.
Unfortunately, I do not have the experimental resources for testing the connector (with network analyzer).
Is it possible with analytical formula or with simulations?
  • \$\begingroup\$ Fix the image, show where coax screens are grounded/connected and explain what 6nnn means in your incorrectly orientated picture. \$\endgroup\$
    Commented Nov 23, 2020 at 10:26
The mismatch loss is almost certainly half of nothing, the connectors length being negligible compared to the ~2M electrical wavelength.
However, if that is an N type, be careful, 50R and 75R N types are NOT compatible and trying will either damage the female or make unreliable contact (depending on which way you try it), the centre pin geometry is different.
