Background:
- I need to write 32 bit data to a receiving instrument, the source of the data is a 32-bit read-only register. This project is time-critical, every clock cycle matters.
- That requires 32 DIO pins, my MCU has enough pins, BUT those pins are controlled by 4 different PIO (Parallel Input/Output Controller).
- The MCU is AT91SAM3X8E. Each PIO controllers have 32 channels, but only certain pins are available for each PIO line. They are defined by 4 bitmasks. Any thing written to unavailable pins (bit mask value = 0) will be ignored.
- So I have to split the 32 bit to 4 parts, and write the parts to 4 PIO.
Context:
data = "some 32bit register value"
mask_PIOA = 0x0018C080; // 5 bits
mask_PIOB = 0x04204000; // 3 bits
mask_PIOC = 0x000FF3FE; // 17 bits
mask_PIOD = 0x0000064F; // 7 bits
Example of what should be written to PIOA:
Data segment PIO mask Desired result
xxxx xxxx xxxx xxxx 0000 0010 0001 1000 xxxx xx1x xx0x xxxx
xxxx xxxx xxx1 0111 1100 0000 1000 0000 11xx xxxx 1xxx xxxx
x = dont care
Question:
- What is the most efficient (cost least clock cycles) way to split the 32 bit data into 4 parts, and fill the 4 parts into 4 masks ("fill" means put the data segment in to the mask bit-by-bit, when the mask value is "1") ?
Comments:
This may not be the answer you want but it's what the question asks... "Most efficient" in clock cycles would be to create your own 32-bit PIO in an FPGA with an MCU core. Xilinx Zynq, Microchip Smartfusion etc offer ARM Cortex CPU + FPGA on the same chip. Then you could write all 32 bits at once. – Brian Drummond
This is actually a good idea, I'm looking into getting a MCU+FPGA board now. But I still want to resolved this with the MCU I have.
Port A - 5 bits using a lookup table with 32 entries
Port B - 3 bits using a lookup table with 8 entries
Port C - no lookup table, just map the bits directly to the port with rotate/mask operations. First copy the 32 bit data, rotate it left once and mask with 0x0000003FE to map bits 0-8 to port bits 1-9, then rotate another copy left 3 times and mask with 0x000FF000 to map bits 9-16 to port bits 12-19. Finally combine the two masked values with logical OR, and send the result to the port through a mask of 0x000FF3FE.
Port D - 7 bits using a lookup table with 128 entries.
This seems most reasonable, thanks !
I generate the lookup table in higher language, because I'm not proficient with C++:
const uint32_t LutA[32] = {0x00000000 ,0x00000080 ,0x00004000 ,0x00004080 ,0x00008000 ,0x00008080 ,0x0000C000 ,0x0000C080
,0x00080000 ,0x00080080 ,0x00084000 ,0x00084080 ,0x00088000 ,0x00088080 ,0x0008C000 ,0x0008C080
,0x00100000 ,0x00100080 ,0x00104000 ,0x00104080 ,0x00108000 ,0x00108080 ,0x0010C000 ,0x0010C080
,0x00180000 ,0x00180080 ,0x00184000 ,0x00184080 ,0x00188000 ,0x00188080 ,0x0018C000 ,0x0018C080};
const uint32_t LutB[8] = {0x00000000 ,0x00004000 ,0x00200000 ,0x00204000 ,0x04000000 ,0x04004000 ,0x04200000 ,0x04204000};
const uint32_t LutD[128] = {0x00000000 ,0x00000001 ,0x00000002 ,0x00000003 ,0x00000004 ,0x00000005 ,0x00000006 ,0x00000007
,0x00000008 ,0x00000009 ,0x0000000A ,0x0000000B ,0x0000000C ,0x0000000D ,0x0000000E ,0x0000000F
,0x00000040 ,0x00000041 ,0x00000042 ,0x00000043 ,0x00000044 ,0x00000045 ,0x00000046 ,0x00000047
,0x00000048 ,0x00000049 ,0x0000004A ,0x0000004B ,0x0000004C ,0x0000004D ,0x0000004E ,0x0000004F
,0x00000200 ,0x00000201 ,0x00000202 ,0x00000203 ,0x00000204 ,0x00000205 ,0x00000206 ,0x00000207
,0x00000208 ,0x00000209 ,0x0000020A ,0x0000020B ,0x0000020C ,0x0000020D ,0x0000020E ,0x0000020F
,0x00000240 ,0x00000241 ,0x00000242 ,0x00000243 ,0x00000244 ,0x00000245 ,0x00000246 ,0x00000247
,0x00000248 ,0x00000249 ,0x0000024A ,0x0000024B ,0x0000024C ,0x0000024D ,0x0000024E ,0x0000024F
,0x00000400 ,0x00000401 ,0x00000402 ,0x00000403 ,0x00000404 ,0x00000405 ,0x00000406 ,0x00000407
,0x00000408 ,0x00000409 ,0x0000040A ,0x0000040B ,0x0000040C ,0x0000040D ,0x0000040E ,0x0000040F
,0x00000440 ,0x00000441 ,0x00000442 ,0x00000443 ,0x00000444 ,0x00000445 ,0x00000446 ,0x00000447
,0x00000448 ,0x00000449 ,0x0000044A ,0x0000044B ,0x0000044C ,0x0000044D ,0x0000044E ,0x0000044F
,0x00000600 ,0x00000601 ,0x00000602 ,0x00000603 ,0x00000604 ,0x00000605 ,0x00000606 ,0x00000607
,0x00000608 ,0x00000609 ,0x0000060A ,0x0000060B ,0x0000060C ,0x0000060D ,0x0000060E ,0x0000060F
,0x00000640 ,0x00000641 ,0x00000642 ,0x00000643 ,0x00000644 ,0x00000645 ,0x00000646 ,0x00000647
,0x00000648 ,0x00000649 ,0x0000064A ,0x0000064B ,0x0000064C ,0x0000064D ,0x0000064E ,0x0000064F};
Then the 4 data to write to 4 ports:
DataA = 0000001F & (Data>>20)->LutA; //mask then point, write 20-24 bits
DataB = 00000007 & (Data|Data>>9) ->LutB; //shift, mask, then point, write 0,10,11 bits
DataC = Data ; //write 1-9,12-19 bits
DataD = 0000007F & (Data>>25)->LutD; //shift, mask, then point, write 25-31
Haven't tested yet because I don't have access to the hardware right now.
Thanks in advance !
