Update - I have now gotten it to work, I took @ChrisStratton advice and found a light weight HAL demo, I started to compare the disassembly and register contents with the demo and found something interesting.
The issue was with GPIOA->MODER which has the reset value I use 0xEBFFFCFF, however in the register view I could see I completely forgot to clear bit 11 - thereby setting the GPIO output as analog :') I also stumbled upon this gem GPIO configuration.
I will update the code in the original question, once I clean it up.
* @file main.c
* @author -
* @brief This file implements the following:
* - Baremetal implementation using the CMSIS library for Cortex-M0+
* of GPIO toggling, specifically the toggling of user LED (LD2)
* via GPIO PA5 on the Nucleo-L053R8 STM32 development board.
/* Includes ------------------------------------------------------------------*/
#include "stm32l0xx.h"
/* Private define ------------------------------------------------------------*/
#define RESET_VAL_PORTA_MODER 0xEBFFFCFF
#define RESET_VAL_PORTA_PUPDR 0x24000000
#define RESET_VAL_PORTA_SPEEDR 0x0C000000
/* Private function prototypes -----------------------------------------------*/
void ConfigureGPIO(void);
* Brief Main program.
* Param None
* Retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32l053xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32l0xx.c file
ConfigureGPIO();
while (1)
// Atomic write - Set [Bit 5] [Val 1] to turn ON PA5 (Port A Pin 5 (LD2))
GPIOA->BSRR = (1<<5);
// Atomic write - Set [Bit 21] [Val 1] to turn OFF PA5
GPIOA->BSRR = (1<<21);
* Brief This function enables the peripheral clocks on GPIO port A,
* configures GPIO PA5 in output mode push-pull enables internal pull-up
* and sets the GPIO speed to medium.
* Param None
* Retval None
static __INLINE void ConfigureGPIO(void)
/* (1) Enable the peripheral clock of GPIOA[Bit 0] [Val 1]*/
/* (2) Select General purpose output mode [Bit 11:10] [Val 0:1] on GPIOA pin 5 */
/* (3) Select Output type push-pull mode */
/* (4) Select Pull-up (10) for PA5 */
/* (5) Select Medium speed [Bit 11:10] [Val 0:1] for PA5 */
RCC->IOPENR |= 0x1; /* (1) */
GPIOA->MODER = (GPIOA->MODER & RESET_VAL_PORTA_MODER) | (1<<10); /* (2) */
GPIOA->MODER = (GPIOA->MODER & RESET_VAL_PORTA_MODER) & ~(1<<11); /* (2) */
GPIOA->OTYPER &= ~(1<<5); /* (3) */
GPIOA->PUPDR = (GPIOA->PUPDR & RESET_VAL_PORTA_PUPDR) | 0x00000400; /* (4) */
GPIOA->OSPEEDR = (GPIOA->OSPEEDR & RESET_VAL_PORTA_SPEEDR) | 0x00000400; /* (5) */
To sum up: This line saved me
/* https://www.st.com/resource/en/reference_manual/dm00095744-ultralowpower-stm32l0x3-advanced-armbased-32bit-mcus-stmicroelectronics.pdf */
