I am considering using an adhesive standoff in an assembly, replacing my current setup of brass standoffs with screws. The current assembly is reliable, but the assembly time of adding the standoffs is something I'm looking to reduce.
General thoughts about the reliability of such standoffs? I am looking at this product, in particular: https://www.digikey.com/en/products/detail/essentra-components/LCBSBM-6-01A-RT/392198
I tracked down the MDS on the adhesive, here: https://www.essentracomponents.com/en-us/component/skuAsset?mediaId=103296
My application is consumer electronics, so the unit can be subjected to heat and cold in transit and generally in a stable environment once in service. My concern is that the board in question is in a vertical position, meaning the board hangs on the standoffs (gravity wants to pull the board down) and that over time the adhesive will become unreliable.
I'm a user of the 3M MP line of adhesives, and they are quite reliable, but you need some surface area. Any thoughts on this would be greatly appreciated!
