I have a 24V / 80W desoldering gun which turned out to have a PTC heating element. I'm not sure why they chose that, as it is intended to be temperature controlled. The resistance of the heating element is about 1.6Ω at room temperature and increases when heated externally.
I want to build a temperature controller and would either go for PWM or a simple bang-bang controller with TRIAC on AC. Since the resistance goes up pretty quickly I have no doubt to be able to control that.
But I'm a bit concerned over the cold state. Currently I would draw around 360W and that would be even worse in winter.
What would be the best strategy to go about doing this? Would it be possible to use a small-ish NTC in line, or would that interfere with the control side too much?
