I am trying the implement the following circuit that was simulated on Falstad. I tried implementing it using the TI NE555 timer IC but it does not work like the one in the simulation.
I want the circuit to do the following
- Output goes to low when a single trigger is detected.
- Output goes to low when multiple triggers are detected. That means that only the first trigger is taken as an input and the rest are ignored.
- Output goes to low when a long trigger is detected. Again, the time duration or the number of repeated triggers are ignored and only the first falling edge is taken as a trigger input
I tried it using the TI NE555 timer IC but the problem is that the output follows the trigger input, goes to high when the trigger is high and low when the trigger goes low. In short, I want the NE555 to work in a one shot monostable mode with a delay of around 900ms.
