I have a very basic question about connecting voltage sources to circuits in LTSpice.
- I started with the macromodel test fixture for the OP27.
- I really like the way the positive and negative rails are defined in the macromodel test fixture. I would like to use the same approach for a noise source.
- I would like to connect my noise source below to R3.
- I am unclear as to how I would connect the noise source to R3 in the LTSpice interface. It is probably very simple. But, I have not found any instructions on how to do this.
I know that I could move the noise source close to the circuit and attach it with a wire. I would like to connect the noise source in the same way that the op amp rail sources are connected.
Do I need to manually edit the SPICE netlist or can I connect the noise source in the LTSpice interface?
Could someone point me to any references that might describe the steps?
The following circuit works. However, I would really like to put the noise source over to the side with the op amp rail voltages.
