I'm making an isolated communication/power module PCB, and I came across a problem that the B0505 isolated DC-DC converter has poor output regulation (+15% to -7.5% under load), and my HCS-LSP hall effect current sensor has requirement of 5V +/- 5% with 10mA rated power draw.
I don't think that the power draw from the DC-DC converter will be so high that it will dip below 5V, as it's only 3v3 MCU reading the hall effect sensor and a voltage divider.
I've read about zener diode voltage regulators somewhere, not sure if that would be the best choice, I've also have some TL431s.
I am aware that the schematic could be prettier. The double resistors/diodes/capacitors are only for SMD/through hole components alternatives.
What is the best way to power the sensor I have with the DC-DC converter I am using? How do I handle the fact that the maximum output voltage of my converter is higher than maximum input voltage of my sensor?
