I am creating an ESC for a BLDC motor. Here is my schematic:
I'm still in the testing stage to make the motor spin with this ESC and while I'm testing, somehow the FAN7392N ICs always break and I have no idea why.
I hooked my circuit up to an LED with a resistor in series and everything worked fine the way I wanted it to. Then I hooked my circuit up to my motor instead of the LED and resistor and suddenly the motor doesn't work.
Then when I try to go back to the LED and resistor to see what's wrong suddenly the LED doesn't work either. Then if I switch out the FAN7392N IC with a brand new FAN7392N IC the LED will start working the way I want it to. So obviously somehow the motor is breaking these ICs.
I've gone through about 6 of these chips now and I don't understand why they keep breaking because I have it hooked up exactly like they recommend in the datasheet.
While testing the motor there were about 2 or 3 times when I had both the upper and lower MOSFET "ON" at the same time which caused a short circuit between the source of the upper MOSFET and drain of the lower MOSFET but it was for less than a few milliseconds. This caused about 7 A to flow through the source/drain for a short period of time.
This short circuit is the only thing that I can think of which could have potentially damaged it, but even then would a short circuit affect the FAN7392N IC since the IC is hooked up to the gate of the MOSFET, not the source/drain?
Despite this short circuit the motor will be running at about 50 A max. so if these ICs can't even handle 7 A running through the drain/source then I've got a problem because I need 50 A flowing through it.
Does anyone have any recommendations so I don't keep breaking these ICs?
