I recently got a cheap Bluetooth speaker. It works fine, but the indicator melodies (the beeps it makes when it turns on and off) are positively deafening. I'm slowly learning about electronics, so my first naive thought was: those "melodies" are stored on the device, so their signal travels a different path to the speaker than whatever I send to the speaker via Bluetooth. If I can identify that path, I could add a resistor there to muffle the sound.
Looking through other questions, I gather that adding a resistor could work, but is a bad idea in many cases. My hope is that I'm in this situation, rather than this one.
After staring at the circuit board for a while, I learned that I don't know enough. I can identify some parts, but not others. The Bluetooth antenna leads to a chip, and I think I found the datasheet here (http only).
The point where I'm stuck is this: Are there components that can be identified as being the amplifier or the memory, or would those be integrated into the chip?
My main goal here is learning, with possible side effect of making the speaker more pleasant to use, so I'm grateful for anyone who can provide some more info. I assume the most practical solution will always be to buy a better speaker, but that's not as much fun, is it?
Edit (gathering info from the comments):
- the component marked M1 is a microphone
- the amplifier is a HAA8002D, and can be muted
