Is there any way to pin point to exactly why reflections would still
be a problem, if the impedance is matched in Ohm, but not necessarily
matching the reactance and resistance separately?
You implied earlier (in a comment) that when you use the term "Ohm" you refer to the complex impedance formed by a resistance and a reactance. If this is incorrect then please say so. Anyway...
If a cable has a complex characteristic impedance then, to prevent reflections, you must use a complex terminator hence you must match both resistive and reactive parts.
But, at RF (greater than around 100 kHz), cables don't have a complex characteristic and, you would terminate a cable in a resistance that matches the cable.
Why am I focussing on cables you might ask; cables have significant length and, are therefore, the exclusive cause of all significant signal reflections.
To understand reflections (and reflection coefficient) we can set up a thought experiment: -
- Assume a cable (transmission-line) of characteristic impedance \$Z_0\$
- At some distance away \$Z_L\$ terminates the cable
- Assume a voltage (\$V_F\$) applied at the non-terminated end of the line
- The current (\$I_F\$) that initially flows into the t-line equals \$V_F\$ divided by \$Z_0\$
When the voltage and accompanying current reach the end of the t-line and meet \$Z_L\$ there will be a potential violation of ohm's law if \$Z_0\$ does not equal \$Z_L\$. We have to fix this violation. The mathematical process of fixing this violation uncovers the meaning of the reflection coefficient.
At no point am I assuming anything about the complex nature of these impedances.
For instance, if \$Z_L\$ > \$Z_0\$ we have to consider a mechanism that prevents the potential violation of ohm's law. The options are: -
- Somehow make the voltage arriving at \$Z_L\$ a bit bigger and, at the same time
- Somehow make the current arriving at \$Z_L\$ a bit smaller
- So, we "adjust" voltage and current in such a way so as to produce a ratio of \$Z_L\$
- Those "adjustments" have to "go somewhere" and, indeed they form a reflection
Algebraically we could say: -
$$\dfrac{V_F + \delta V_F}{I_F - \delta I_F} = Z_L$$
In effect I've added a "bit" of voltage and, subtracted a "bit" of current. It drills-down like this: -
$$\dfrac{V_F}{I_F}\cdot \dfrac{1 + \delta}{1 - \delta} = Z_L\longrightarrow Z_0\cdot \dfrac{1 + \delta}{1 - \delta} = Z_L$$
$$\text{Hence,}\hspace{1cm}\delta Z_0 +\delta Z_L = Z_L - Z_0$$
$$\text{And,}\hspace{1cm}\delta = \dfrac{Z_L-Z_0}{Z_L+Z_0}$$
But, of course, we call \$\delta\$ by it's usual name (reflection coefficient) \$\Gamma\$. The symbol \$\delta\$ is just a device I invented to get through the thought experiment.
However, the important subtlety that prevents an ohm's law violation is the "bit" we add to voltage and the "bit" we subtract from current (\$\delta V_F\$ and \$\delta I_F\$).
If we examined their ratio we would find it is \$Z_0\$. This means that they can naturally flow (together) back into the transmission line because they have the perfectly correct ratio to do so.
That is called a reflection and travels from load to source.
Clearly, if \$V_F\$ and \$I_F\$ were originally of a ratio that matched the load (\$Z_0\$) impedance (right from the start), we wouldn't need to set up the algebra that figured out how to deal with the unwanted signals and, there would be no thoughts of violating ohm's law nor talk of reflections.
