I need help to identify this IC:
Context, truck gate driver:
  • \$\begingroup\$ From a TV or other audio/visual device? \$\endgroup\$
    – KristoferA
    Commented May 26, 2023 at 14:56
    \$\begingroup\$ "9718" is possibly 1997, 18th week. \$\endgroup\$
    – rdtsc
    Commented May 26, 2023 at 16:15
  • \$\begingroup\$ why do you need to identify that IC? ... what problem will that solve? \$\endgroup\$
    – jsotola
    Commented May 26, 2023 at 16:58
  • \$\begingroup\$ Could it be 8k x 8 SRAM, 12 address lines + 8 datalines + 2 for power, leaves 2 control lines for enable en read/write \$\endgroup\$
    – hennep
    Commented May 26, 2023 at 17:31
  • \$\begingroup\$ @hennep 8K needs 13 address lines, so that would be a bit difficult to fit in a 24-pin component. Unless it’s some kind of ROM rather than RAM. \$\endgroup\$
    – jcaron
    Commented May 26, 2023 at 20:43
ES2 (European Silicon Structures) was a company that made fast-turn custom chips using (then cutting-edge) electron beam and CAD technology.
So I don't think you're going to get any useful information from other than the OEM documents for whatever product that thing came out of. Image from Linkedin.
