I want to know the cut off frequency of this circuit, given that the GBW is constant (1.9MHz) and R1=8.2kOhm and R2=114.6KOhm. I did 19e6/2*\$\pi\$*R2 (since it doesn't have a capacitor) but my calculations aren't right.
What I am doing wrong?
Get some lin-log graph paper and do this: -
The 3 dB point of your amplifier will be about 130 kHz. If you need a more exact answer, turn the graph into a formula.
You have accepted an incorrect answer. John D's comment is correct.
Whether we are considering a non-inverting amp or an inverting amp, the bandwidth is given by GBW/Noise Gain = GBW/(1+R2/R1) = GBW*beta where beta = 1/Noise Gain.
So, assuming that the phase of the openloop gain is -90 degrees (falling at -20 dB/decade) where the horizontal Noise Gain plot (1/beta plot) crosses the openloop gain plot then, at this frequency, the closed loop gain of a non-inverting amplifier and the closed loop gain of an inverting amplifier will both be down 3 dB from there low frequency values. This assumes that the two amplifiers have the same Noise Gains (1/betas). Of course this leaves you with the characteristic of the inverting amplifier that it has less closed loop signal gain than the non-inverting amplifier for the same bandwidth. For example if an inverting amplifier is configured for unity closed loop signal gain with a Noise Gain of 2 then a non-inverting amplifier with the same Noise Gain will have a closed loop signal gain of 2. Both amplifiers have the same Noise gain and closed loop bandwidth but the non-inverting amplifier has double the closed loop signal gain compares to that of the inverting amplifier.
Strictly speaking this assumes that the open loop gain is falling at -20 dB/decade = -6 dB/octave which is approximately true for most of the amplifier's openloop bandwidth.
And so in your case the closed loop bandwidth = 1.9 MHz/14.98 = 126.9 kHz.
as the OP will receive a notification and see your answer regardless. You may want to edit and amend your answer by removing the first couple of lines (which would have served better as a comment under the other answer).
Commented
May 29, 2023 at 21:27
